Took my buddy for a ride in my car tonight and on a pull I thought I lost a rocker arm, I had a stud pull out last fall on an old set of highports. It's probably had 50 pulls on it since then with no issues.
Anyway I nursed it home about a half a mile and pulled the valve covers and to my surprise didn't see an issue. Rockers are all tight, studs are bottomed into the guide plates, so I started it up and at idle it's quiet, tap the gas and it rattles. I pulled the plugs and cranked it around and checked each rocker for a collapsed lifter and they appear to be good. Plugs all look good, IAT's were fine and looking back at the logs from the fall, there's no change in average oil pressure's. Is it possible to spin a rod bearing and not loose SOME oil pressure? I'm at a loss here.
