1 - 10 of 10 Posts
Im trying a new tuneup this weekend on a ST 2 stage diffuser. turning it into a single stage with a progressive. Im using a 82n 73f in both ports. I have 2 regulators 1 for each fuel solenoid. What fuel pressure should I start at?
Is this on a SBF? Better watch all the plugs close and keep it conservative. That will be like 550hp throug a plate.
I run a single difuser plate and with those jets I run 5.5 PSI with 950/975 on the bottle.
"Made" Member
Thats a pretty big jet spread.. i only run a 4 jet spread on my two stage diffuser.
Man thats exactly what im spraying right now 82n-73f on 5 1/2 pounds of fuel pressure 1 regulater no problems we are fixing to put the big boy jets in sbc in a mustang.
"Someday"
you sure it aint 5lbs??? Im gonna check it when i get back. FordSux:
Is Speed Techs websight working? I can only access there front page only. I have been unable to scroll or navigate anywhere on their sight.
I would start at 5.5 fp and be conservative on timing
And alot of times the 4 jet spread isn't enough
1 - 10 of 10 Posts
