1 - 5 of 5 Posts
I know what plugs have worked well in the past on my 23* motors, but I am curious to know what is recommended by those of you that run the 15* and lower angle haeds? The heads I am using are GM 615x milled to 13.5*. Any recommendations or advice is appreciated.
Thanks, Steve
N/a or poweradder?
N/A I use a NGK -8 generally for the quicker burning fuels, and for a poweradder i use -9 or -10 depending on the situation....
Also I use a R5672A which is an extended tip for n/a and a R5671A retracted tip for power adders.
1 - 5 of 5 Posts
