1 - 4 of 4 Posts
You can cut the crimp off the top of the hex and pull the entire porcelain out. This is easiest on a lathe but I suppose if you don't have access to a lathe you could stick it in a vice and do it with a cutoff wheel or even a hacksaw. Sometimes it takes a little working to get the porcelain out.
1 - 4 of 4 Posts
