This one is killing us. Need some help. My brother has a Vega with a 355 sbc supercharged and can't keep the wires from arcing out to the headers and other places.He is running a MSD -6BTM, a MSD Blaster HVC coil and a MSD Pro Billit dizzy. everything is new.
Just some notes, not sure if it means anything
When we first tried to fire up the engine it would not even pop until it was discovered that 2 wires were crossed. Corrected them and it fired right up as normal. Weird
-- Tried timing light on engine and it was reading like 140 degrees. We finally figure out it was picking up from another wire that was close to #1 and timing light pickup. Separated wires more and now it was at 32 degrees total.
- The engine throws off a ton of heat in a very short time and stays real hot for a while after you shut it off. He runs it with out a hood but it doesn't seem to matter. Except after one short ride he said it cooled down like a normal car. It has only done that once.
- He has tried several types of wires and now hase a new set of Moroso Blue Max with Moroso wire sleeves. The plugs are Autolite 3934. gapped around 22
- Just tried all grounds and added a new strap from the block to the frame and ran a direct ground from battery to MSD box and coil.
Sorry it's a long one but hoping someone has a clue or has run into this themselves.
