1 - 8 of 8 Posts
Hey guys just curious if you guys have had a spark plug look like detonation got it from making a pass on a low bottle? Made some passes and last on was bottle was gone and mph/et was way off and when I got home to change plugs I noticed number 5 plug looked bad but was the only one. No different tune then before with no problems before. I did drive the car around on the plugs later that night with N/A timing on them so it had motor time on it also. Sbf 175hp shot with 116 in the standalone and a mix of 93/116 in tank with timing locked at 25*. Ill post a pic later
Discussion Starter #5 (Edited)
Compression test with one pump
cyl1-120
cyl2-120
cyl3-110 I think piston was up alredy
cyl4-125
cyl5-120
cyl6-125
cyl7-120
cyl8-120
Compression with 3 more pumps after first hit was recorded
cyl1-170
cyl2-165
cyl3-170
cyl4-175
cyl5-175
cyl6-175
cyl7-170
cyl8-175
One thing that might be worth doing since its free and easy, is OHMing the wires and see if 5 is seeing a weak spark?
Discussion Starter #8
No anti seize so probably a little oil. Didnt think of it untill you said the wires but that wires boot is right under the valve cover breather and oil drips right on it... right where the plug wire runs into the boot.
1 - 8 of 8 Posts
