I have a BBC 635 inch on Q16 Gas 3200lb NA car. Motor make over 11000hp I currently run Autolight AR3933 is this a good plug to run or can I go faster with another, Thanks
Man that is alot of HP.. 11,000 Plugs will not make you run faster. They will only last longer if they are the proper ones. I have ran the same set for a whole season in my N/A setup.
I would have to disagree- if you are way off on your plug it will kill power, I changed from ngk-9 plug to a autolite 3910 in my bbc and the motor pulled alot better in high gear and e.t. went from 5.69 to 5.65 just with a plug change!
You should give up a little more if its that cold you may have a bit more timing than you need in it. But a plug recomndation from what you have given is throwing a dart
