sorry for delay on answering some of these questions, went to the pdra race yesterday to spectate since my trans is still apart
any ill try to catch up
the motor is 392 cubic inch sbf
diamond pistons at 4.076 bore
tfs-r heads cnc ported 60 cc chambers
the turbo is from chris at crt it is his dual 6 blade billet wheeled 88mm based off of the garret gt55
as for changing fuel thats not gonna happen i got alot of c16 and im not gonna switch to something that is not very friendly to sitting around
as for rotor phase im using a price motorsports cam sync set at 185 degrees btdc in accordance with the holley instructions
the crank trigger is set at 60 degrees before tdc and i have verified timing at idle and 3000 rpm with no need for a change on inductive delay
the plug gap is actually at .022 and ill attach some pics of the plugs
the car also seems to take a good bit of time to start up while cold which i was kinda attributing to the cold plugs
i have a few sets of plugs and its not a big deal to sway out to a hotter heat range
does the consensus say to drop one or two heat ranges ?
as for the wires my only gripe with them is the stupid multi angle boots and how much of a pain in the ass they are to get onto the plug and how ya cant really tell if they are all the way clicked on
are the firecore wires any better for this ?
it takes longer to put the plug wires back on then it does to change out all the plugs and gap em
heres some pics of three plugs
they all look like this
