1 - 20 of 56 Posts
Typical Chevy guy rhetoric. It's best in the twisties, around the ring, in the water, etc. Everywhere else but on the actual road in a race against a Ford.
Government cut em a good deal on bulk engines.
X2
well said.. LOL
That engine is a LSA and it comes frome Detroit sir.
Same engine in the CTS-V and the ZL-1
Engine
The powerplant in the 2009 CTS-V is a supercharged OHV 6.2 L LSA V-8, based on the LS9 V-8 from the recently released Chevrolet Corvette C6 ZR1. It produces 556 hp (415 kW) and 551 lb·ft (747 N·m) of torque.[5][6] The choice to use an Overhead valve (OHV) arrangement (also known as a pushrod engine) is unique in the luxury performance sedan market where competitors typically use dual overhead camshaft (DOHC) engines.The engine is produced in GM's Silao, Mexico engine assembly plant. The LSA engine has a bore and stroke of 4.06×3.62 inches (103.25×92.0 mm).[5] The engine block is cast aluminum 319-T5 alloy with cast-iron cylinder liners. The crankshaft is forged steel using powdered-metal connecting rods. Pistons are high-silicon Hypereutectic Aluminum alloy replacing the forged aluminum used in the LS9 engine. The compression ratio is 9.1:1. The cylinder heads are based on the Corvette's LS3 head and are cast from type 356-T6 Aluminum alloy. The exhaust manifolds are cast iron. The supercharger is a twin three-lobe Roots-type unit displacing 1.9 L. It is Eaton's Twin Vortices Series (TVS) generating a maximum boost of 9.0 psi (62.1 kPa). Intake air is cooled with a water-to-air intercooler
Elite Member
Viva La Mexico ! LOL
Its too bad they didn't use the Coyote, at least that motor would have been made by the skilled hands of fellow Americans !
1 - 20 of 56 Posts
