1 - 9 of 9 Posts
I have a solar plasma cutter 2040 that quit working. it was doing fine then it just quit, so then I replaced the tip but it still don't work. anybody know of something internal that would keep it from working right.
I would contact the manufacturer, the distributor, or a local repair place for that kind of advice. Plasma cutters are relatively complicated pieces of equipment, and expensive!
Grade 8 Motorsports
Any clogs or pinches in the air line?
Bad relay?
Discussion Starter #7
no there's not any pinches in the air line. what is the air pressure it should be set at? there are a set of what look like points in there, should they be replaced maybe?
They call me HateTank
Some have a contact in the tip that can cause it not to work if the tip is not reassembled properly.I've also had light duty ones stop after excessive use from over heating. Had to let it cool and it fired right back up.
1 - 9 of 9 Posts
