IW Baby!!!:shock::shock::shock:
Dat dere is sum purty wowwww! What is that balancer? Never seen one like that before. Reluctor on it and all.... damn nice
It is GM LS7 heads same ones that come on Zo6 corvetteNice piece! LS3 headed.
That's cool. I had thought about doing a build on one of those for a dirt track deal, but heard the factory heads are weak in the valve spring seat area. Is this true? What kind of solid roller spring pressures will they tolerate?It is a 6 liter block like what comes in a 2500hd truck and the heads are GM castings that was cleaned up a little and a allpro manifold that took a lot of work because they cast those things to be cnc'ed so they are kinda small so that every thing cleanes up when they cnc it. The only trick thing is the vavle train which I will post some pics after we go to engine masters
Nice. Excited to see how it scores!It is GM LS7 heads same ones that come on Zo6 corvette
