1 - 5 of 5 Posts
Sho'Nuff
yup
there was only about 15% difference in the chassis design from 79-2004. It's about the most interchangeable suspension, ever.
yes as long as you use bushing out of a 99 in the arms. in 99 they went to a slightly larger bolt. 13mm up till 98 and 99-up its 14mm iirc
Discussion Starter · #4 ·
I was wanting to go to big bolt setup any way so that's cool. I like to pick up parts used when I can.
oh and not to be a smartass but 99 up is considered new edge...94-98 is the sn95
1 - 5 of 5 Posts
