1 - 20 of 42 Posts
Ford guys, I swapped in a small bellhousing C-4 behind my cleveland with a 157 tooth flywheel but I can't seem to find a starter that works. I have tried one from a 95 Ford Bronco with Auto trans and one from 90 Mustang auto trans but they are both 164 tooth. What late model starter can I get that will work or what old ass 25 lb starter do I need.:confused:
You need a small starter that comes in the Lincoln LSC with the 5.0 engine...I think its
a 97 or 98 ...I know its a late model like that.....but it will do the trick
When I check online the part numbers come up the same for most of the small block stuff. I had this same setup on my Mustang and it worked fine. I didn't think that the mid plates/bellhousing were different for the 157 and 164 flywheel but they are, they position the starter in a different place. So far I have yet to try a manual trans starter but that looks like my next stop or maybe trying a new original starter. When I hit the ignition I get a serious grinding sound like the gears are mismatched.
The bellhousing locates the starter. IF your bell is for a 164 tooth it will not work. There is not a starter made to fit that combo, 157 tooth wheel and bell for 164.
Actually the small bell Cruise-a-matic was used from 64-69. In 1970 they came out with a new bellhousing. You can get a 164 tooth flywheel with a dipstick in pan or in case. I have used many times and on Clevelands a 157 teeth flywheel, bellhousing and a 1993-1994 Mustang or F-150 starter.
Discussion Starter · #15 ·
Thanks for all the replies, here is what I have guys;
Case Fill C-4
Small Bellhousing
157 tooth flywheel
My old combo had an C-6 with 164 tooth flywheel, I tried to use that mid plate and the starter wouldn't work so this is what confrims that I have 157 tooth small bellhousing. I think I have a large bellhousing but that would mean buying another SFI Flywheel. I prefer not to pull the tranny if I can find the correct starter.
Smitty
ran into the same problem. ive got an sfi bellhousing on my C4/ 302 ford and the powermaster starter would work. kept hitting the oil pan and wouldnt line up with the bh. was told to get a starter from a 93 cobra. question is my flywheel is 157. I just went to Autozone and got a starter but havent tried it yet.
The bell housing centers the starter ,the starters will all work, the mustang auto and manual one are the same
Wrong.
They are not the same.
1 - 20 of 42 Posts
