1 - 13 of 13 Posts
Bastardization Engineer
I have a 2000 Dakota, Calvert split monos, caltracs, Viking DA's relocated vertical in front of the axle and should be in the 800-850hp range and around 3,300lbs. Was considering putting sliders on it. I haven't ran it yet, but getting close and wondering if I messed up not putting them on when I did the rest of the suspension.
Look at how Tin Soldiers Racecars makes their slider kits height adjustable. Really slick set up to their slider kits.
65888
Anything you can do to help with free movement of your suspension will help. Not that you're going to pick up big numbers, but it will allow the rear of the truck to work better. I ran them on mine when I used to run leaf springs.
Jeff
I’ve got the Tin Soldier setup shown. Brand new. All CM. Mid-course decided to back-half the car and go 4-link. I paid $650? Will sell it for $400 shipped to 48 states. I think it’s the ultimate for a leaf car. You can change ride height, angles, anything.
FYI - I previously went from factory style shackles to sliders. It’s definitely an improvement. PM if interested
Yeah, that is a really great deal. Always after I spend a bunch of money. Haha If you have them in a couple weeks I'll take them, if not I'll understand. Been trying to get it able to make one of the drag week stops in Michigan this year.
It’s not advertised anywhere. Email me and I’ll send you pictures. [email protected]
FYI - When I’m in a wallet crunch, I use PayPal. Anything over $100 is no interest for 6 months. I always payoff within 6 months and I don’t feel the crush all at once.
Yes, install sliders. Just redid mine. You need to get the mounts - front/rear - and the spring perches square so there isn't any bind with solid alum bushings at both ends of the spring.
Was looking at you car and noticed the fuel cell hanging under it. Doesn't the cell need to be boxed in a metal box when secured outside the trunk?
Discussion Starter #12
Not sure, If it does, I can build on pretty easy. I just looked and I think it only needs to be on the three sides and bottom. Though, I don't think they care around here.
1 - 13 of 13 Posts
