What's the build? If this is a grudge car and you don't want to say I understand...i figured as much...would it make a difference with the build? or is it ALL up to your oppinion?
reasoning?single
what class? what tire etc. I would and plan on running a single, there are advantages to each but most every class will allow a single, not all will allow twins.reasoning?
no class, grudge.what class? what tire etc. I would and plan on running a single, there are advantages to each but most every class will allow a single, not all will allow twins.
hell yeah it would!Kolivas just went 4.70's with 275's and a single. That should win a few grudge races!!!
334ci i would like to go mid 5's without pushing it hard.
i probably could. but i want to be able to turn up the wick when the need arises. i want to run mid 5's with minimal stress.pshhh ,you could do that with a single 88mm..
