1 - 13 of 13 Posts
I'm looking at what could be a deal and could be a PITA...it's what I think is a shorty glide but I have a few questions.
1. Can I run a regular driveshaft? I read somewhere the yoke could just be shortened? I don't have a 9 inch (Winters rear) so I can't run a CV shaft.
2. What are those big holes up front on the case? Converter cooling? Foot killing?
A Senior Member
Looks like it is for a RED.
I wander how this ended up being used as shorty for a dragster? Someone had to run it like that.....I guess maybe a low power setup....
I never seen anyone run a shorty in a car with a long shaft either...
Discussion Starter · #7 ·
Sounds like something weird enough to be a pass....it was only $500 with converter so I was a little hopeful but probably just save my cash towards a "normal" glide.
A Senior Member
  • Like
Reactions: str8liner
Many years ago I had a neighbor that ran circle track with holes in the bell just like that. I believe the holes were to run hoses to front pump in a converterless powerglide. He used a ball valve in car to engage pump. I at least think that is how it may have worked. Probably wrong.
The promotion states you'll get two free nights, but you'll be charged for three. You still get two free nights if you're staying three nights or more. Most of the time, the rooms are in high demand and the "stay three, play two" promotion helps you get discounted rooms. There are several hotels in the desert that are not attached to the casino. These places are cheaper but not as close to the casinos.
Who is this loser? Scammer. Wipe his ass with a boot.
$500 if it's got a TB valve body and useable parts it's worth that especially if the case has cooler ports. Plenty with the bellhousing holes out there racing and if it cracks buy an ultrabell. For a door car swap planetary gear and puta tailhousing on it.
1 - 13 of 13 Posts
