1 - 5 of 5 Posts
05 Colorado (all steel) 3800 lbs.
5.3 sbe w/ billet 78/75 w/1.32 ar 810 rwhp
Turbo 400, 2.48 1st, brake PTC 9.5" 5200 flash
8.8 rear w/3.73
Cal Tracs w/stock front and rear shocks and springs w/helper removed
275/60/15 M/T drag radial pro
9.90 @ 136 1.48 60 ft.
have video (do not know how to load, can send from facebook) for someone to critique and see if it is hitting the tire too hard. we have little over 5" front end travel and 5" extension on rear. Cal Tracs are in upper hole. Thanks
Discussion Starter #2
1.4 60 ft. now would like 1.2- low 1.3
any ideas for front shock conversion ? dual adjustable for rear
How much are you leaving on? What rpm are you leaving at? DA's all around imo. Slow the front extension down to stop the f/e from pulling the wheels. Tighten the front compression so it keeps the nose up and gradually returns to ride height. In the rear, loose extension with tight compression to keep the tire driven into the ground. I see the front wheel come off the ground, but you can't keep them up there, so it unloads the rears as your fronts are touching back down. Stop the front wheels from leaving the track surface by slowing front extension.
5-6 psi., 3600 on 2-step. drag radials have 12 p.s.i. in them. Colorado has the shock
with spring and 3 bolt top mount, (strut) and come to find out no one offers anything
front conversion yet. should we try limiters ?,and let it raise how high ? Thanks for your
advice.
1 - 5 of 5 Posts
