Judging by the numbers it's most likely a 153-155 mph passbruders 159mph plus wow!!!!Thanks MAYhem
thee numbers?Judging by the numbers it's most likely a 153-155 mph pass
Way .. Way over your head ! You would need a library for two years then BANANNAS will explain it to you !thee numbers?![]()
right ur a super genius that never races,right bought a 60k car that sits in garage.CMAFR:Way .. Way over your head ! You would need a library for two years then BANANNAS will explain it to you !
Deans also made a couple 159 hits. Also saw Pirez go 158 either everyone found some mph or something is off.They just went 4.63 @ 160. Looks like the 1st mph was legit huh B.Laster?
For $20k I'll take it out to take care of you , no balls !! Then I'll drag it down the street and set it on fire , cause I can !! Now what PUSSY BOY !!right ur a super genius that never races,right bought a 60k car that sits in garage.CMAFR:
