1 - 4 of 4 Posts
Is there any good info out there on setting up a IRS on a 3rd Gen Supra? The car done ok when stock but with a 450-500hp sbc I assume Im going to have a time getting it to hook even with good radials. I have dialed in a bit of possitive camber to correct when squatted still need to set toe in tho.
Spend money on good double adjustable shocks, and remove any flex in your rear suspension, Eliminate any rubber bushings and brace the diff. if you can replace any rubber bushing to solid aluminum pucks or spacers, Great!
1 - 4 of 4 Posts
