1 - 3 of 3 Posts
On my 408 Im running the Billet MSD dist(out of box)How much timing does it add to my base timing? I set the timing at 14 at idle then does the MSD add 14 on top that for total 28?
Some have told me to set timing by Holding the RPMs up,to were the timing stops going up as you are using your timing light.Thanks for any help.
our 408 sbf likes 34 degrees total. like steve said you can lock out your distributor and even at an idle itll read what your setting is i would try 34 degrees the msd digital 6 has a retard built in it for starting the car..
1 - 3 of 3 Posts
