1 - 5 of 5 Posts
Hey
On the servo cover there are three bolts that hold on the cover. what is the small bolt/plug on the bottom right for? Thanks
Hey
I imagine you are talking Powerglide.
The small port is for a pressure reading.
You can read both low and high gear line pressure there. In low there's pressure on the outside of the piston; in high on both sides. Some later Glides had a separate port in the case ahead of the servo area that you can read just high pressure at. It was used for a spark retard switch.
1 - 5 of 5 Posts
