Looks like the Shark fits this Class.
OSCA: Bradco Engineering True Street Class 2005 Rules & Regulations
Stock front fame rails required
After market front suspension components allowed (must bolt-on and mount in stock mounting points)
Rack and pinions steering allowed
Must have inner fender wells (minor modifications allowed)
Stock rear frame rails required (notched frame OK)
After market stock type rear suspension allowed (must bolt on)
No rear coil-overs allowed
No wheelie bars, four links or ladder bars allowed
Anti-sway bars allowed
Leaf springs may be moved in-board (relocation of rear shock allowed)
Must have working head lights and tail lights
Must have functional charging system
Must have stock appearing interior
Must have full interior (no metal visible)
Must have dash
Rear seat may be removed
No lettering on car
Decals only on windows
No Lexan allowed (except for truck rear window)
Windows must be operational
Fiberglass limited to hood, trunk lid, and bumpers
Single four barrel only
OEM fuel injection allowed (common upgrades allowed)
After market fuel injection allowed only on V6 applications
Limited to a single plate and a single stage of nitrous (one nitrous and fuel solenoid)
No nitrous controllers or timers
No alcohol (gasoline only)
Single turbo or supercharge allowed on blow-through car or OEM style fuel injection (V8 applications only)
All turbo/superchargers with OEM style fuel injection set-ups must be a maximum of 4" inlet and 3" outlet
All turbo/supercharges with a blow-through carb setup have no limits on inlet and outlets
No sheet metal intakes allowed
Must have mufflers
Rear tires are limited to a 10.5 slick as measured (10.75 inches) or 12.5 DOT (11 inch footprint) tires
Cars must be driven to staging lanes (no tow vehicles)
2900 lbs. naturally aspirated
3150 lbs. small block with nitrous - V6 with turbo/supercharger
3250 lbs. small block with turbo/supercharger
3300 lbs. big block with nitrous
3350 lbs. big block with turbo/supercharger
Add 50 lbs. for dominator-style carbs
Add 100 lbs. for after market fuel injection on V6 applications only
Add 100 lbs. for a fogger system
Cars with leaf springs may change to ladder bars with coilovers
Shocks may be moved in a max of 3 inches for tire clearance (bottom only)
Once car has been entered into true street it may not fall back into Mild Street for remainder of season
Rules subject to revision when needed
