1 - 4 of 4 Posts
Probably a stupid question, but here goes. I'm adding a second kit to a cast tunnel ram. I have everything I need but the plates. My set up has an aluminum spacer under both carbs for clearance issues, they both already have an 1/8" not port on both ends. Could I used 4 nozzles (already have the old set from my fogger when I upgraded) in those spacers n jet accordingly? Thanks
if it were me id just put the plates on and roll on the nozzels will work but unless you get the aim at the ports perfect you might run into issues with distribution why create issues
1 - 4 of 4 Posts
