1 - 2 of 2 Posts
Concerning scoops, how is it setup internally, E.g., the isolator tray, inner pan etc all get installled in the scoop. What do you need to install in the scoop and where do you glue/mold it into the scoop?
Thankx
What i have done in the past was to dzus fastn the scoop to the car/motor and set the hood on over it. On the inside of the scoop i built a alum. tray that fit around the carb. But if you have a scoop that is part of the hood, its easy to make a pan that stays on the carb and I have seen guys use foam that extends from the bottom of the hood to the pan.
1 - 2 of 2 Posts
