what are my options on digiset timer? need to delay the nitrous out of the hole a little. need one that will be reliable. Not looking to spend a ton, but pending on my options I will.
we use the arc also.. but if u need more that 1sec. delay they wont go any higher... you will have to doubble up.Here's something that I have used with good success:
http://www.jegs.com/i/ARC+-+Auto+Rod+Controls/116/1402/10002/-1
if your using a 6530 use the launch retard that will be pleanty enough to get you off the line with the jet restrictions that are in place for RS275the car will be using a MSD 6530. With the class we run we cant use a 7 series box, or any box with slew or anything. So I have to use some sort of timer just to activate the nitrous a little bit out....
The car leaves real hard on motor alone. will go 1.34-36's on radials on motor and then bringing in the nitrous around 30-40ft out.....
im going to play it by ear. I knew the box had this option, so Im gonna have both and see which works best. Thanks and see you the 3rd of April!if your using a 6530 use the launch retard that will be pleanty enough to get you off the line with the jet restrictions that are in place for RS275
Yes we usually only needed a .2 to .4 delay to get it to work without a progressive and heck for 41.00 bucks you can't beat it!
