1 - 6 of 6 Posts
Hi guys, I'm in the process of building a .40 over Windsor (fully forged) with victor jr head and victor sr intake. Probably going to use a S475 turbo blow through application.
Anyone have an idea of what cam would be good, I was thinking I want to do a solid roller! Hoping to make around 700hp to the tire. Thanks
Depends on the intended use. Street or track?
700 is not a big deal and can be done with a hydraulic.
You'll want to get a Jr. intake with maybe a gasket match and some balance.
I have a mild solid roller that would work very well with that setup. But as mentioned, 700hp at the tire is very easy to accomplish. You'll want more power as we all inevitably do, so plan accordingly. Lol
I went 10.8's with a stock block Windsor 383 and a tiny 7668 in a 4410lb truck using a small .236/.236 .555/.555 lift cam shifting @6100. Made around 640 or so to the tire. You won't need much to go for the power your looking for.
Thanks guys. Car is a track only toy looking to shift around 65-6800rpm, just hoping some of the cam gurus had specific cams that would work well with this combo!
1 - 6 of 6 Posts
