What endplay seems to be nominal, bearing type any tricks that help?
Seems to be workingTorrington works nice.
Do you happen to have any photos of this little trick?Drill a small hole on the side of the lower main through the bearing. This keeps oil pressure between the thust bearing and cap. I haven't had any thrust issues in 15 years doing this with blowers and turbos. Good luck.
Got any more info on something like this? It's been coming up in my searches recently. I'm killing thrust bearings now myself.60psi by-pass valve on the trans cooler line .
PM this guy ^^^^^^ he knows what worksDrill a small hole on the side of the lower main through the bearing. This keeps oil pressure between the thust bearing and cap. I haven't had any thrust issues in 15 years doing this with blowers and turbos. Good luck.
