1 - 6 of 6 Posts
I've tried to put one on my car and there is no room between the lower rad hose and the balancer, has anyone else had this problem, if so what was the solution, besides a meziere and csr!!!
HELLL YES!!!!
I have a large balancer. Innovators West-6 bolt pulley, with crank trigger magnets.
I use the Meiziere and the -16 adapter for the lower hose. The big -16 AN fitting had to be ground down to clear the balancer. The back edge of the crank trigger tabs had to be milled slightly as well.
I doubt it would have fit at all if I used the hose adapter
Discussion Starter · #4 ·
not much of a set up, the pump is supplied with two options for an output, one on the pass side and the other on the drivers, when in the driver side it just clears the balancer by like an 1/8th inch, with no room for the hose, the pass side is no good, i dont want to buy another rad, the hose adapter supplied is straight, if it was like 22 degrees it'd work, i have no pics available
1 - 6 of 6 Posts
