1 - 20 of 56 Posts
Just wondering what were some of the quickest nitrous cars been to the 1/8th using victor jr heads.
I've been [email protected] at 3050# with a doulble cross plate jetted with 2x.085's
I did my own porting and when I had them freshened up with new valves last go around my head guy said he touched them up a little bit. I only took away material from around the valve guide area and they flowed around 315 cfm at .600-.650 lift on the intake and exhaust was generally around 75% of that. I took and machined the diagonal header pattern into the exhaust side so I eliminated the adapter plate, that was always a restriction on mine because the bolt holes were so close to the port.
those are some pretty decent heads. 2yrs ago my brother dropped a valve the night before the nmra charlotte race. we put the spare short block in and the only heads laying around was a set of victor jrs, straight out of the box. anyways, he ran pretty good and won the race, nmra renegade. he went 5.58 and 8.70. that was with a 1.30 60ft but it was august in charlotte,nc --car normally went 1.23-1.24. 347, hyd 550 cam, wilson plate.
Discussion Starter #12
Who is real good at getting the MAX out of these victor jr's. I have had a real good cnc program done on them, but I was wondering if anybody could do a hand blend after the fact to get any more out of them.
kuntz and co.
What size valves do you have in them? What csa are you at, and what size/rpm of motor?
Chapman. My brother has been 191 with a set ported by them. At the time a rep from Edelbrock said that was the fastest with them. It was a turbo car though, out dated 98mm.
Discussion Starter #17
I still have the stock 2.05/1.60 valves. I have no idea what csa means!!! Motor is a 9.5 deck 427 and I spin it about 7800
Discussion Starter #18
How much will putting a bigger intake valve help out?
You have some room to grow for sure! The bigger valve helps on big inch motors, cause it opens up the mcsa(throat). Csa is the actual measurment of the port size, not cc's.
I have a version that flows 340 and will make over 720 hp na in a nitrous motor. DTS dyno.
1 - 20 of 56 Posts
