1 - 6 of 6 Posts
347. brodix m2 heads,14.2to1comp.. cam installed @105.5 108.0 lobe sep. [email protected] in.278 ex.284.cam lift. in .696 ex.683.. both intakes have been gasket match(1262) and minor plenum work..witch one be best with this combo..This is in a s/s coupe with powerglide, 5800 converter and 4.71 rear gears @ 2750 lbs..
Is that a custom cam if so I have the same specs as you and it works great but I run CHI4.0 intake with 255cc THS H.P's.
yes.. custom grind by comp cams.. cars run good with the super victor. just picked up the funnel web and was wanting to give it try..
1 - 6 of 6 Posts
