1 - 4 of 4 Posts
anybody have any tips or ideas (pics) of how to setup a crank trigger on a sbf application WITHOUT motor plate, but with driver-side mounted vacuum pump and alternator?
i see in other forums where people are machining the wheels or balancers for alignment clearances.
i've got a flat-faced balancer with the 3/4" (or 1/2", unsure) spacer then the aerospace pulley and mandrel running the aforementioned belts.
thanks guys
I used the Innovators West setup. Call them, I have a motor plate but it is not needed to work with it. I also have an Alt and a Vac pump on the pass side.
MSD makes a kit for SBFs.
1 - 4 of 4 Posts
