I am starting to get parts together to finally get rid of my factory 5.0 block, hopefully before i run into problems. With so many options I was wondering which would be the best fit. For starters, it will be a NA 363 10.5 : 1 neutral balance pump gas combo hoping to make peak power around 7800 and shifting around 8k. It should stay that way for a few years as I work on the chassis/ suspension setup for more power than it will make NA. Down the road I plan on adding a meth kit and a small blower to get it up to around the 800hp range to reach my final goal of 150 mph in the quarter. Which block to you guy recommend? FRPP 8.2 BOSS or one of the Darts? No, I don't want to go 8.5. Thanks
