1 - 19 of 19 Posts
what kind of timing are you guys running for 15-20 psi of boost on sbf's running e85? Trying to just get a feel for where i should be at. Thanks.
Setup is an 76mm with an a2a cooler, efi, aluminum headed 347 with approximately 9:1 compression burning e85.
I've got a 9:1 SBF 347 on E85. I have a CSU E85 prepped carb. I'm currently using a plug in addition to my 7al2 box, the msd timing/boost #8762. With the initial timing set at 35 on the dist., the box starts pulling timing out at 5lbs of boost. I 'm trying to get a consistant 25lbs of boost so the timing should be at 20deg when the boost reaches a minimum of 20 lbs. The box pulls up to 15 degrees of timing in increments of 1-3 degrees per second. I just started using this system so I have no real e.t slips. I did use the system on the dyno but I had the initial timing kinda low (30) so my pulls were only at 15 degrees of timing @ 28lbs of boost. It was suggested that I could turn the initial timing to about 40 degrees so the box pulls down to 25 at the 28lb boost level.. This is through a rather large a/a innercooler. On the dyno the car made over 900 rwhp... FWIW....
As previously stated, 20-22 would be a nice place to start. I also like my afr in the 10.8 - 11.0 range...
26 deg with E85. 18lbs of boost with a Precision 78GTS. 347cu, 8.5 to 1, small solid roller, A2A. I gained over 150hp by going from 20 deg to 26 deg on the dyno.
Do you have dual needle and seat bowls on the carb?
Awesome. Gives me some hope when I get my tune dialed in from a low 15* to a solid 25ish.... :cool:
A buddy of mine has an extremely similar setup to this. At 20lbs and 24 deg just went 5.76 with more 60ft left and a 3"downpipe.
1 - 19 of 19 Posts
