1 - 7 of 7 Posts
· Premium Member
Well I recall those heads take a normal guide plate? I've never tried to use an offset lifter with a guide plate in the standard position. You'll have to mock it up and see if it will work from just a fitment standpoint.... The guide plate is going to act like a fulcrum, and the resultant pushrod angle at the lifter, will also exist(not to the same extent) at the rocker but in the opposite direction(can you visualise this?) But that's important because that guide plate is the only thing locating the rocker on the valve.... I'm pretty certain the rocker tip will no longer be properly located on the tip of the valve..... of course none of this is taking into account the dynamics of the resultant pushrod angularity.... certainly not ideal. But if you have the stuff laying around it might be worth a mockup to see the results.
· Registered
Actually comp cams makes a guide plate just for this head.
Isky makes the "sliding" guide plates that your referring to Chris.
tom cowle
PS if you use these heads, fill in the dip in the intake runner, the engine will love that.
1 - 7 of 7 Posts
