1 - 12 of 12 Posts
has anyone had any luck with these heads? im building a 406 that will be run with some spray every now and again but i saw some pro filer heads at a swap meet and the quality looked awsome just wondering if anyone is running these heads
i don't run them myself, but i know people who have said it's a great bang for your buck deal. i'm definitely considering getting some for my next motor.
thanks for the info guys these what im gonna plan on buying unless something goes wrong with my budget. its going to be a 406 with h beam rods, proobably 12/13:1 pistons and hopefully a domintator, im thinkin on going with the 2.055 or 2.08 valves wat do u think?
Butch
Here is what mine flow
Flowed @ 28" on a 4.070" bore fixture, 2.055/1.600 valves. Gasket matched and bowl ported as they come from Pro-Filer.
ACFM
Lift No. 1 No. 2
0.2000 143.0 96.2
0.3000 204.3 150.1
0.4000 249.7 178.0
0.5000 284.2 198.8
0.6000 299.6 211.0
0.7000 299.6 218.1
0.8000 301.9 221.3
0.9000 301.9 222.9
1.0000 299.6 222.9
Average: 264.9 191.0
We did do back cut valves and I sent in a few different valves for Darin to play with and he came up with,,,
Intake Valve
12° x 3/8"
45° x .065"
30° x .080"
Pro Flo valve
The exhaust did great with the 18 to 22 degree tulip valves.
I asked Chad just this week specifically about valve sizes for these heads in relation to bore. I was curious if they could be had with a smaller 2.02 valve for a 4 inch bore motor....or would shrouding be a non issue with the bigger valve with the smaller bore.
He said the 195 and 210 were actually designed around a 2.02 valve initially, and the head could be ordered with a 2.02 if somebody wanted. He also went on to say that the chambers in them are a little wider than typical and he personally runs the big 2.08 valve in everything. I didnt have him expound on that but I took it to mean that the wide chamber helps the ports flow nice with the big valves even into a small bore. And especially if its a larger 400 variety bore....he would like to see the bigger valve.
At 4.155 inches with potentially 13:1 compression and a dominator....it sounds like the sort of build where Chad would probably want to put you into a 2.08, but id probably see what he thinks.
Those are really nice heads but i would go with the 2.10 intake for anything over 360+ci. JMO
1 - 12 of 12 Posts
