I don't know a whole lot about the sportsman block.... I had a customer give me one recently for a 427 build(4" stroke what a nightmare)....85Camaro said:Chris where can I get some info in one of those little M sportsman blocks. What kind of power will these things hold up to? who makes these blocks?
SOMETIMES the mains need to have a hone thrown thru them.... but, really if you were in a money crunch, take a new one, check everything closely, detail it up, hone cylinders to size and RUN IT. The machine work is decent.68 nova 10.5 said:on my 377 had a few problems wish I had bought an aftermarket block as well . but one question I would like to raise is how much additional machine work is there to be done to the block ?
Do you know how much a iron eagle block runs with steel caps just looking on line I see them for 2500+.Chris Uratchko said:I don't know a whole lot about the sportsman block.... I had a customer give me one recently for a 427 build(4" stroke what a nightmare)....85Camaro said:Chris where can I get some info in one of those little M sportsman blocks. What kind of power will these things hold up to? who makes these blocks?
should make 700-750 horsepower n/a somewhere between. He gave it to me to use, I didn't buy it but he said it was 1200 bucks. It has main bolts instead of studs. I'm a little surprised that steel caps alone would add that much to the cost.... I would prefer steel caps, but the iron splayed will take some abuse.... it's not like the 30 year old iron used in stock blocks.
But far as I can see it's all the same as a normal Little M save for the caps.
BTW Dart makes it. You can check on their website or call them for more information I wish I had more for you.
man I wish I new this 3 years ago I could have purchased a block for about $1895 @ the time I think I spent $1650 on mine I was thinkin I would have spent $400 - $600 on additional machine work ! this market needs a good reputable machine shop that dosent try to bend ya over all the time . Thanks for the info ChrisChris Uratchko said:SOMETIMES the mains need to have a hone thrown thru them.... but, really if you were in a money crunch, take a new one, check everything closely, detail it up, hone cylinders to size and RUN IT. The machine work is decent.68 nova 10.5 said:on my 377 had a few problems wish I had bought an aftermarket block as well . but one question I would like to raise is how much additional machine work is there to be done to the block ?
Now a lot of machinists might balk at that as they are in business to make money machining.... I'm am not in the business of doing that. I'm in the business of making horsepower and designing the engine so you'll get a little different story that is unbiased from me.
