1 - 5 of 5 Posts
What do u guys like to see??? using clevites and a 4 inch stroke callies in a lil m block
what is your method of checking????
what about thrust clearance as well
thx
Butch
thx
.0028"-.003" on mains, .0032"-.0035" on rear main bearing, if you don't have an extra counter weight on the crank that main should also be .0032"-.0035", all others .0028"-.003"
Rods depends on rods and crank pin roundness
End play is good at .0065"-.007"
not to jack a thread but how about bore size? say a .040 over thats measuring .044 .when is it too loose? i know some like to run a lil loose but what is acceptable?
1 - 5 of 5 Posts
