1 - 19 of 19 Posts
SBC Just keeps on Rolling…. And Pullin’
In 2015 Bobby Bammann of Bammann Racing Engines in NJ had a customer that needed an engine for his 1954 Chevy Truck….in full Rat Rod. The truck is built on top of a custom $25,000 Art Morrison fabricated frame that is fully bagged for ride and comfort. Customer wanted a solid power plant that would idle at 800 rpm, but have some “get up and go” using old school mouse power. So a SBC 427CID 4.125 x 4” stroke was selected. A Dart SHP block was used with a forged rotating kit. A set of AFR210 heads “out of the box” capped with Super Vic intake and an Ultra 750 completed the induction. Bammann used Straub Tech for the camshaft and lifters. Straub supplied a camshaft that is .612/570 244/248 on a 108 LSA with a set of 4708 Morel Ultra Pro Hydraulic rollers that would be used with the OEM Spider and Dog-bone system from GM. With compression set at 10.5 to 1, the big mouse made 581HP at 6100 and 594#/ft at 4700…..we don’t know when the engine breaks 500# ft as the dyno doesn’t read that low!!!!
The engine was stuffed in the truck and off the customer went racking up over 60,000 miles on the truck till June of 2019 when the plan changed for the truck…grandpa was taking his grandson on a trip around the United States in the truck……Pulling a 27’ 7600lb trailer!!!!!!!!!!! Remember this is a Rat Rod….built to run around town and burn rubber….it wasn’t built to Haul loads…it was built to Haul Butt!!! Grandpa consulted with Bammann and after some advice, a hitch installation, and a full tank of pump gas…..the adventure was on….
Bammann got a call a few weeks later when the pilot and copilot got to Rockies and engine seemed down on power. Bobby gave them a jet change and timing change that he was comfortable with to help with the loss of power. The next time the phone rang it was a tech out in Las Vegas and he had some questions about the engine combination for tuning reasons of the new Holley Terminator System he was installing!!! There was one thing that was puzzling the tech….all cylinder were 170psi of cranking compression except for number 1….it was 220 psi. Bammann hypothesized that intake valve must be closing sooner on that cylinder for some reason and was the reason for the increase cranking compression. Since the engine wasn’t missing, it wasn’t a concern at the time. Down the road Bammann would realize how correct he was about closing early.
Terminator installed, the family vacation of exploring the US continued. From July 3 to December 15th the pilot and co-pilot logged over 10K miles in the “transformed” hotrod now tow truck. Bammann and owner both agreed after 4 years and 70K miles on the SBC, it was time for a rebuild. During the rebuild Bammann found the reason for the 220-psi cylinder. The intake lobe on number 1 was in failure mode. The worn lobe had lost nearly all its lobe lift with around .080” left, but nothing on the heal of the cam lobe was warn. So, the engine had lost power but since nothing was gone from heal of the lobe, the lifter never lost preload and the engine was able to continue without a “miss”.
Looking back, Bammann feels the lobe was probably going when the first call at the Rockies came in. The amazing part is the Grandpa and Grandson kept on rolling just like the engine did.
Bammann is in the process of freshening the “big mouse” right now the emphasis on “towing” since Grandpa and Grandson are thinking Canada now. One thing Grandpa told Bobby….” you use the same parts in that engine again because I know I won’t get stranded”
52737
52738
52739
52740
52741
Going to drop down to a VicJr and camshaft will be smaller. If the next trip goes way up North going to need more grunt....Kudo's to Bobby Bammann Racing Engines in NJ for building one hell of engine that no ever guessed would get 70,000 miles put on it 4.5 years. None the less it would be pulling 4 tons!!
Bammann is in the process of freshening the “big mouse” right now the emphasis on “towing” since Grandpa and Grandson are thinking Canada now. One thing Grandpa told Bobby….” you use the same parts in that engine again because I know I won’t get stranded” View attachment 52737 View attachment 52738 View attachment 52739 View attachment 52740 View attachment 52741
What would cause that? I could see it if the lifter fell apart, but what the hell caused it to go flat?
SWEET !!!! Cool fun !!!!!
Discussion Starter #9
Heat. The wheel on the Morel is still rolling. Would not have used that core if I and the engine builder had known what the owner would do. Not many hotrods get driven 70K miles in less that 5 years. Needless to say tow 4 tons for 10K miles.
I have a ls that makes that power ,waaayyy less cam .Its over the 100k mile area in 5 yrs.Pulls 5th wheel trailer that's heavier than that an I'm sure it gets better milage!!And it's still running!After seeing that cam I would be worried about all metal ran through entire engine.
With torque like that on pump fuel I'd be afraid to change anything, other than maybe more cubes. On his way to Canada eh!
Lifter not centered on the lobe that's gone at all.Wondered if ate edge and kept going?
Look at the roller patterns exhibited on the other lobes. What do you see?
Very likely just the camera angle in pic , but the the wheel looks like it has worn into the left side fork . Axle out of parallel from dog bone flats ? Dog tracking wheel + cast core = failed lobe ?
Discussion Starter #16
The time spent with the Grandson is Priceless.....no matter the cost of the gas money.
that is a very stout sbc and very envious of grampa taking grandson on the trip of his life , but any further post-mortem other than simply saying "heat" for the questions asking about the one failed lobe ?
Discussion Starter #19
Bobby is pulling the engine down. I will post what info I do get.
1 - 19 of 19 Posts
