SBC 23 Degree Jesel Pro Aluminum Series Shaft Rockers. 1.5-and 1.6 ratios. .250 offset on the intake and Zero on the exhaust. Standard slot. Pro Aluminum Series Shaft Rocker Arms — Jesel Valvetrain
This is a complete set with steels stands, bolts for stands, bolts for rockers and shims. These are the rockers that only can be brought through your machine shop. 800.00 OBO
two sets of QA-1 12 inch length coil springs, 150 and 130. 45.00 each.
SBC Bullet Cam with 2-7 swap. 55 mm cam Journals, Gross valve lift Intake -776, Exhaust-690 . 400. OBO
SBC Bullet Cam, standard Journals. Gross Valve lift, intake .475, exhaust .456. 300 OBO.
Moroso on head spring tester 0-300 50.00 OBO
Moroso on head spring tester 160-400 100.00 OBO
Manley push rods SBC 3/8 : 16- 7.925, .135 wall, 3706. 125.00
7- 7.775, .080 wall 1013 50.00
8-7.700 .135 wall 4615 90.00
6-7.825 .080 wall 4107 40.00
8-7.650 .135 wall 3716 90.00
Buyer pays shipping
Pictures on request
Call 203-858-1952
Bob Lasko
[email protected]
