1 - 9 of 9 Posts
Have a sbc its will be a nitrous motor 4.130 bore and 3.875 stroke if i was using a rr 23 degree head what would they need to be as far as min. Csa, runner cc and valve size also what would the cam specs need to look like lift, duration and events want to operate around 8500 rpm at the shift spraying a max of say 40-44 pill
Butch
Dart's 220 RR heads are nice and I think they would do you well.
The head or casting you use will play effect on valve size, but 2.125-2.150" would be the range for most. 2.80-3.25"sq.in, The cam will need to be in the .800-.875"+ range.
Just depends on a lot of factors.
Goals?
Car set up?
I have a set of all pros now 290cc runner,2.18 intake ,3.02sq inches at p-rod pinch but didnt know if i needed to have them sent in to make them fit my application better, no real goal just go as fast as i can with stuff i have 4.70-4.80, 2600lb 4 link chassis truck
EFI/N2O JUNKIE
My RR All Pros have a 246ish intake runner. Not sure exact size, poured them a year ago. I bought them bare and had them done for a 414, shift at 8000, go through at 8200ish.
Discussion Starter · #9 ·
I have a dart intake for use with a tall deck block (9.300) just to give an idea it has been welded around the carb flange and was ported thru the original material and into the weld
1 - 9 of 9 Posts
