1 - 3 of 3 Posts
I got a F2 procharged SBC with the MSD7531 box. I also have a crank trigger. I start the timing at 35*. Does it need to be phased at 35* or what? I have not ran this engine and will be my first time starting it.
You can roughly set it around 35 for starting purposes, it doesn't need to be real close. Before you put any load on the engine you need to phase it at whatever timing you want to run under a load.
1 - 3 of 3 Posts
