I am looking for a custom grind cam for my 350. What I have is a 358(.060 over 350), Ross .250 dome pistons, Dart Iron Eagle Plat 230 heads 64cc 2.08/1.65 valves, 230 seat pressure springs 550 open pressure, 1.6 rockers, block has been zero decked with the piston .005 in the hole, Pro Products Hurricane single plane intake, 850 dp with some work done to it, 4.10 rear gears, and M21 4 speed. I will be changing this to a glide with a brake and 4500 stall and 4.56 or 4.88 gears. Right now I have a .630/.627 lift, 264/272 duration @ .050 on a 110 lobe sep. I will be spraying the engine but not every pass. Probably 60% of the time I will be.
