1 - 5 of 5 Posts
looking for a off the shelve cam. For a 406 with 12.8.1 com ,head flow 347 at 700, 1.6 int and 1.5 exh rockers looking to spray 200 to 250. Car weights 3200 with 400 and a 28 tall tire, using a double cross nos plate also any pointer would be great, The cam i was looking at is 264/[email protected] 635/645 lift on a 112
To get the most out of your combo you should I would call bullet camshafts. They may have something on the shelf, but if I was you I would go with one of their custom grinds for your combo. A custom grind only cost $400.00. It would be worth looking into!
i wouldn't run the lsa out that wide if all you're doing is a 200-250. a 109 or 110 would be a little more ideal. duration can come up too, another 10 or so on the intake and another 10-15 on the exhaust. hope this helps
the cam i went with 718int 680exh 277/284 @50 on a 108 so it will run decent on motor and good on 200 shot
1 - 5 of 5 Posts
