i am bulding up a small block for my nova and cant figure out what cam i should go with. this is mainly a street drivin car that will see the track. it will be a 383 stroker, eagle forged crank with eagle stroker clearanced 6 inch rods. and compression somewhere around 10:1 or 11:1. edelbrock rpm heads and an air gap manifold. keisler rs 5 speed trans with a 2.80 first gear. and a 10 bolt locker an 3.42 rear gears (may change to either 3.73 or 3.90 depending on how it drives). i have a holley 4777. may need to go bigger. hooker super comp headers with 1 3/4 tubes to a 3 inch flowmaster exhaust. which one of these cams would you guys think i should run. all are lunati. the solid rollers i will do the 4/7 swap on.
1. Hydraulic roller, lopey idle. Great street machine cam! Likes upgraded intake carburetor and exhaust. Needs 9.5:1 or better compression and 2500 RPM stall speed converter and a 3.42 or better rear gear ratio.
Advertised Duration (Int/Exh): 282/290
Duration @ .050 (Int/Exh): 231/239
Gross Valve Lift (Int/Exh): .535/.550
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2400-6200
Includes: Cam Only
Part Number: 60112
2. Hydraulic roller, rough idle. Serious street and bracket race cam. Needs 10.5:1 compression ratio. Needs 3000-3500 RPM stall speed converter, 3.73 or better rear gears, aftermarket intake, carburetor and performance exhaust system. Excellent power and torque above 3500 RPM.
Advertised Duration (Int/Exh): 294/302
Duration @ .050 (Int/Exh): 243/251
Gross Valve Lift (Int/Exh): .560/.565
LSA/ICL: 110/106
RPM Range: 2800-6400
Includes: Cam Only
Part Number: 60113
3. Solid roller, rough idle. Good cam for high performance street or mild strip applications. Needs 2500-2800 RPM stall speed converter, 9.5:1 or better compression, aftermarket exhaust system and 3.73 rear gear ratio.
Advertised Duration (Int/Exh): 267/273
Duration @ .050 (Int/Exh): 237/243
Gross Valve Lift (Int/Exh): .566/.578
LSA/ICL: 110/106
Valve Lash (Int/Exh): 016/016
RPM Range: 2500-6800
Includes: Cam Only
Part Number: 60131
4. Solid roller, rough idle. Good cam for high performance street/strip applications. Needs 2800-3000 RPM stall speed converter, 10:1 or better compression, aftermarket exhaust system and 3.90 rear gear ratio.
Advertised Duration (Int/Exh): 273/279
Duration @ .050 (Int/Exh): 243/249
Gross Valve Lift (Int/Exh): .578/.585
LSA/ICL: 110/106
RPM Range: 2600-7000
Includes: Cam Only
Part Number: 60132
5. Solid roller, rough idle. Excellent cam for high performance street/strip applications. Excellent mid to upper RPM torque and horsepower in 355-383 cubic inch engines. Needs 3000-3500 RPM stall speed converter, 10:1 or better compression, aftermarket exhaust system and 3.90 rear gear ratio.
Advertised Duration (Int/Exh): 279/285
Duration @ .050 (Int/Exh): 249/255
Gross Valve Lift (Int/Exh): .585/.600
LSA/ICL: 110/106
RPM Range: 2800-7200
Includes: Cam Only
Part Number: 60133
also which lifters should i use for each one???
LSA/ICL: 110/106
Includes: Cam Only
Part Number: 60112
LSA/ICL: 110/106
Includes: Cam Only
Part Number: 60113
LSA/ICL: 110/106
Includes: Cam Only
Part Number: 60131
LSA/ICL: 110/106
Includes: Cam Only
Part Number: 60132
LSA/ICL: 110/106
Includes: Cam Only
Part Number: 60133
