1 - 2 of 2 Posts
I see these are rated at the same hp just the 500 has a bigger wheel...
Any other diffrences? Size? Weight?
Any feedback on these from people who have used them would be great
Well theres a big difference in size and weight between the 400 and 500 chassis.. 400 is about 40-45 pounds...500 is 55-60. Depending on which housings are on em.
500 has about 6 different A/R choices on the turbine housing... 400 you are pretty much locksd into 1.
Wouldnt use the 400 on anything bigger than 300-330 inches. 500 would work up to 380-400.
S400-88 is better suited as a twin setup.
1 - 2 of 2 Posts
