1 - 9 of 9 Posts
I am looking for estimates on horse power and times, so when I hit the dyno I have ideas, to make sure I am in the ball park
plan on 20 pounds of boost on track, more after new block is installed
What size slick should I run?????
63 Chevy 2
3300 pounds
383 stroker
DFI ACCEL GEN 7 750 cfm throttle body
92 pound injectors
s480 turbo with Billett racing cover
Tial wastegates 44 mm .08 bar spring
and BOV
Lunati 585 solid lift cam ( Voo doo cam turbo grind)
pro comp aluminum heads
4340 crank
4340 rods
8.9 to 1 compression
9 inch ford Narrowed 370 gear Locker
Accel fuel pump ( that big one LOL)
aeromotive pressure regulator and filter
AMS 1000
pro torque stall convertor
th 400 trans
Four link, with a chassis works bolt on front end
If I need to add any specs let me know
Custom Engine Shop
It'll never run...... :butthead:
Custom Engine Shop
You have a pm
63 Chevy 2
3300 pounds
383 stroker
92 pound injectors
and BOV
4340 crank
4340 rods
AMS 1000
th 400 trans
Paul:
You can expect a max of 1050 to 1100hp at the tires letting its tounge hang out on race gas is it has our Race Cover. The BW cover is good for about 100hp less on average.
Regards,
Wildbill
Discussion Starter · #7 ·
Thanks a lot guys least I have something keep my tuner in line
Custom Engine Shop
Any slick recommendation???
The biggest that will fit. Give a shout there are a couple of things to do and not to do on the chassis dyno. And I don't type that fast.
1 - 9 of 9 Posts
