1 - 15 of 15 Posts
any reason I cannot idle my blow thru with carb hat off, really struggling with idle and would like to set it up and then see if it changes cheers
mine idles with or without the hat. what is it doing?
No reason at all. Try it.
great, is very responsive but cant get idle below 1500 so makes pain on street
I read another post on here one time with a guy having the same trouble. Several chimed in and said their carb wouldn't idle without it hooked up also.
When the car is idling there is no boost with or without the hat on.so the car should idle fine.
Discussion Starter #7
thanks will let you know my findings tommorow, got good vacumn, timings right and have checked everything for vacumn leaks but it is just a normal carb with different floats. wondering if there is a bit more to a blow thru carbs than i first thought
cant just run a normal carb hoss.they are some changes need to be made.i run a modified holley 4150 hp.guys changed a good bit on mine.get ahold of csu or [email protected] for help with the carb.
Hey Preston, you got you Blowthru running yet. I'm starting on one too.
i had the ebay kit.they spool real fast.i belive they was 63/60 eventually leaked thru the seals.hope yours came out better than mine.only thing i kept was the oil lines and fitting and the headers.cut the ends off went vbad and swapped everything out.i went a 6.14 with it on a 355 sbc.good luck with it.
Custom Engine Shop
X2.
How is the boost ref regulator tubing ran?
Regulator should go to the bonnet not the manifold.
Make sure the rear blades are not cracked open too far and make sure none of the blades are bent and not letting the throttle close all the way.
Discussion Starter #14
no matter what we do you can always see day light around butterflys, starting to think bad casting. will try and compare to a new barry grant friend has, if wrong will have to rob piggy bank for a proper blow thru carb, cheers for your help
Take the baseplate off and loosen the screws on the blades and see if you can get them to fit better in the bores. Sometimes there is a little play for adjustment in the blades.
1 - 15 of 15 Posts
