I tried pulling the serp. belt on the dyno and it went lean on the pull 15:1 afr...it steadily climbed there from 13:1...
I was on a stock ls1 pump and it might have been maxed put needed the whole 14.4 volts to flow enough fuel...
I now have the aeromotive 340 pump and might give it another try...
Is anyone running no alt. on a 12v setup, can it be done...
Looking to pull the belt for a run or two with the negative DA coming, some have said it was would .05-1 tenth...anyone ever test this?
thanks
Chris
thanks
Chris
