1 - 17 of 17 Posts
· Registered
I know this can be done but will all windows OS work? I have an HP laptop with 7 on it and want to have 95 on it to so I can play some old games I have. Burnout Pro especially. I downloaded DOSBOX and can't get that to work. After searching Google for how to do multiple OS I think I would just Phuck up my computer if I did it myself. Is this something I can just have done by a computer shop? If I cant get DOSBOX to work I know trying to install multiple OS would kill me.
· Registered
well you can format your hard drive to have multiple partitions... install a os on each one and use a boot loader to choose what partition to boot from.
Pretty simple. But as for runing multiple os's on the same partition or simultaneously... idk.
· Registered
I put vista and xp on a laptop some years ago for a guy at work, I think it was vista causing the problems but it never worked right. BSOD as well as random lock ups, and if you ran a defrag on the drive with vista it would lock up. Then I wanted to make it work so I tried two HD with one OS on each drive and still random look ups, went from one lockup a day to once a week with separate HD but still not stable. That's my experience anyways.
· Registered
Discussion Starter · #7 ·
Is this something I can have "the geek squad" or somebody like that do for me? I would need someone show me how to use it to. Would I be better off to just buy another used cheap laptop with 95 on it and use that for the old games?
· Registered
x2 for vmware. You can just install it under win7 and have as many guest operating systems as you like depending on HD size.
Multiple paritions using a bootloader is another option, but is a little more advanced to setup.
· Registered
95 can't read FAT32 or NTFS file systems and newer operating systems aren't going to work very well with an older disk format. You'd be better off getting an old "clunker" to run the old games on - should be able to find something pretty cheap at a used computer store.
1 - 17 of 17 Posts
