I picked up a slight skip in my engine. So I'm doing some PM stuff tonight and while checking the Ohms on the plug wires I find the lugs inside the cap are dark colored and I have to scrap the lug with the meter lead to get any reading at all. The cap only has 130 passes on it. I pulled the rotor off and it too was dark and I had to scratch the tip to get a reading to the button pick up. I put the cap and rotor in the glass bead cabinet and cleaned the lugs up. Now they read fine. Anyone see this before? I run a crank trigger and this is a MSD cap, rotor, and distributor and they were all new 130 passes ago. Wonder if that could insulate the gap and hurt the fire to the wires? Maybe I'm just over thinking this? RM
